Date/Time: Mon, 24 Feb 2025 18:21:47 +0000
[User Discussion] - Percent Change Indicator
View Count: 806
[2021-03-09 06:33:27] |
rwilliams1 - Posts: 346 |
Is there a way to have the Percentage change indicator start at a specific point and stay anchored at that point? Right now with the First Bar in Chart/Time Period Type Length options will always be updating when new bars are formed and the oldest bars are deleted so the indicator will not stayed anchored to the original point which will change the current reading. Any help is appreciated.
Date Time Of Last Edit: 2021-03-10 02:19:06
Attachment Deleted. ![]() |
[2021-03-10 02:19:46] |
File attached
![]() Attachment Deleted. |
[2021-03-10 02:21:59] |
Just attached two screenshots to show what I'm talking about. First screenshot is from March 4th, and the second is from March 9th. The graph continually shifts because the first bar in the chart keeps changing. I need to find a way to permanently anchor the first bar so that the graph reading won't continually change making it hard to gauge the readings. Any help is appreciated. FYI, ALTHOUGH THE SCREENSHOTS ARE OF THE SUBGRAPHS DIFFERENCE INDICATOR, THE SUBGRAPHS DIFFERENCE INDICATOR IS BASED ON TWO PERCENTAGE CHANGE SINCE OPEN INDICATORS. Date Time Of Last Edit: 2021-03-10 02:27:39
[2021-03-19 19:34:44] |
Would it be possible to add an "anchor" parameter for this indicator so that users can anchor the start point to a specific time/date that doesn't move?
