Date/Time: Tue, 04 Nov 2025 18:18:13 +0000
Period Length for Exporting Intraday Data
View Count: 2439
| [2013-04-20 16:22:57] |
| User87197 - Posts: 65 |
Hi, I'd like to export intraday data as 60 min rows instead of 1min which is what i'm getting. Also it's exporting ALL data for the symbol, regardless of the chart settings "days to load" number. Can I export less than the whole file? Thanks so much, I know the solutions must be super-easy!! :)
| [2013-04-20 22:13:50] |
You will need to use the Write Bar Data to File study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s182 You will need to increase the Days to Load in Chart Settings to the number of days you will want to export. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
