Date/Time: Mon, 24 Feb 2025 09:45:22 +0000
Additional option for Drawing Tools
View Count: 446
[2021-03-09 05:36:22] |
nicktrader - Posts: 738 |
I have linked some of my charts regarding drawings. But in some cases I don't want to see the drawing in the other TF. Is there a possibility to offer an additional option where you can say not visible in other linked charts? Many thanks |
[2021-03-09 16:20:53] |
John - SC Support - Posts: 38116 |
Yes, you can do this on a per drawing basis. Refer to the following: Chart Settings: Excluding Specific Chart Drawings from Being Copied For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-09 17:00:39] |
Many thanks - works perfect
