Date/Time: Mon, 24 Feb 2025 09:00:16 +0000
market order attatched stop not following OCO
View Count: 519
[2021-03-09 02:01:21] |
User356762 - Posts: 37 |
Hello, ive looked through all the settings i could think of and tried reading through the attached order page but cant seem to figure this out. When i market in off of my trade dom, my stop order isnt 8 ticks away like i set it. sometimes its 2 ticks, sometimes 4, etc. when i limit in it is working fine. Is there a setting im missing somewhere? TIA |
[2021-03-09 15:56:12] |
John - SC Support - Posts: 38116 |
Exactly what kind of Stop order are you adding in the Targets tab of the Trading window? What is the Offset Type set to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-10 13:52:21] |
stop is a stop all, stop: stop. offset is in ticks. |
[2021-03-10 16:18:57] |
First thing we want to do is to update to the current version of Sierra Chart: Software Download: Fast Update Make sure this setting is enabled: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
