Date/Time: Mon, 24 Feb 2025 12:30:09 +0000
no numbers on numbar bar chart
View Count: 550
[2021-03-09 01:34:58]
User798547 - Posts: 54
hi
i just updated to denali 10 and i am not getting any data to my number bar chart, i have some movement but no data is getting to my charts
[2021-03-09 15:53:09]
John - SC Support - Posts: 38116
You need to be on Package 11 in order to use the Numbers Bars study. Refer to the differences in the packages here:
Description of Service Packages and Pricing: Packages
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
[2021-03-09 16:07:08]
ok i will try
am i going to have to pay again, i feel like ive paid for 3 different denali feeds this month, i was told i needed 10 now i need 11, am i getting charged for all 3
thanks for the reply
[2021-03-09 18:38:20]
You are not getting charged each time. When you change a service package the only thing that changes is the end data of your Usage Time. It gets recalculated based on the previous package and the new package selections.
[2021-03-11 19:04:59]
Sierra_Chart Engineering - Posts: 18548
Let us know if you still need help. We can give you a call to help you.
