Date/Time: Mon, 24 Feb 2025 19:28:36 +0000
New Billing Change Notification
View Count: 528
[2021-03-09 00:55:51] |
User696540 - Posts: 28 |
Hello, I've got 2 accounts with AMP Futures and I'm using the "Free" Version of SC on each account. Is there a change being made to the "Free" option with AMP? Thanks |
[2021-03-09 03:48:05] |
Refer to this thread for complete information: Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker You only need to pay for Sierra Chart once and you can use two installations of Sierra Chart if you need to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-22 22:48:22] |
Hello I have 2 accts at AMP I'm running SC on 2 different computers. One for acct "A" on one computer, and a 2nd instance of SC on the 2nd computer for acct "B" I assume now that the "free" version of SC is no longer available from AMP That I only need to pay for 1 instance of SC charting? How do I configure this on the 2nd computer so that I don't need to pay 2 SC charting fees? Thanks |
[2021-03-23 09:14:49] |
That I only need to pay for 1 instance of SC charting? Yes. How do I configure this on the 2nd Nothing special to do. Just follow the instructions here to install a second installation:computer so that I don't need to pay 2 SC charting fees? Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
