Date/Time: Mon, 24 Feb 2025 09:20:53 +0000
Data
View Count: 404
[2021-03-08 19:42:19] |
User366058 - Posts: 9 |
Hi guys Not completely sure I understand the data options. I need real-time on: FDAX 6B 6E CL ES ZN NQ How to do that? Best Chris |
[2021-03-08 20:20:18] |
John - SC Support - Posts: 38116 |
FDAX: EUREX 6B: CME 6E: CME CL: NYMEX ES: CME ZN: CBOT NQ: CME Given these exchanges, you need to use the Denali Exchange Data Feed. You would need the data for EUREX. And then for the CME Group, you would be best served to use the Full CME Group options, since you need a total of 3 exchanges, either with or without Market Depth, depending on your needs. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
