Date/Time: Thu, 24 Sep 2026 03:45:50 +0000
[User Discussion] - Re: Multiple monitor support : displaying toolbar menu on 2nd monitor
View Count: 2255
[2014-03-01 00:22:52]
mario mario - Posts: 22
displaying toolbar menu on 2nd monitor, is this feature available now, if so how to make it display on 2nd monitor also.
Default Re: Multiple monitor support
You can move the main Sierra Chart window to any monitor on your system. The Toolbars will display only on the main Sierra Chart window and we are working on support to allow them to be on a detached chart.
__________________
Date Time Of Last Edit: 2014-03-03 01:43:40
[2014-03-03 01:43:24]
No, not yet. Currently though you can detach a ToolBar from the main window and you should be able to place it on another monitor. Although it may not always work entirely as expected.
[2015-03-13 16:21:56]
phaedonk - Posts: 352
Is this on the roadmap? I tried the suggestion of the detached toolbar, but its not practical. Plus, it hides beneath other windows and does not have a placeholder on the Ultramon taskbar, so I can reclick it.
Thanks.
[2015-03-13 17:33:22]
We are currently building a new ToolBar.
[2015-03-13 18:20:02]
George - Posts: 60
If you use a variety of tools on different monitors, you might want to consider a programmable mouse. I use one that has 10 programmable buttons plus the normal left/right click buttons and scroll wheel. It works across all monitors and saves alot of time.
[2015-03-17 09:28:04]
Can you tell me what mouse that is? So you can program "10s" for example, to get a 10 second chart with one click? Sounds interesting, thanks.
[2015-03-17 11:29:09]
George - Posts: 60
No, not for a 10S chart, it is used for assigning tools to the buttons on the mouse. Like, click a button and draw a trendline, click another button and draw a rectangle, without having to go to the tools menu and select trendline and then draw it. Have you ever heard of a gaming mouse? That is the kind of mouse I use, I do not play games with it, just assign different tools to each button. Mine is about 4 or 5 years old, works great. Why don't you do a search for programmable mouse or gaming mouse and see if it's what you're looking for?
[2015-03-31 13:53:27]
ganz - Posts: 1048
SC Support
Is there any ETA?
May I ask you: do you think the Qt5 based libs and dev-tools are stable, reliable and well designed at this moment?
I'm testing the new MOEX Terminal now. It is Qt5-based and multi-platform as well http://ftp.moex.com/pub/FORTS/test/Terminal/
thnx.
