Date/Time: Mon, 24 Feb 2025 09:17:35 +0000
software speed problem
View Count: 460
[2021-03-08 17:15:28] |
hatem hosny - Posts: 57 |
hello, - when i disconnect the data feed, the software's speed is normal(open,close, change chart book, mouse movement,etc). otherwise the speed is very slow, o example the mouse cursor is moving v slow. what should i do? this problem has been for almost 2 months, even i reinstalled the software on another drive, but this is not working. than you |
[2021-03-08 18:22:38] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
