Date/Time: Mon, 24 Feb 2025 07:35:22 +0000
Denali tick feed vs. CQG feed
View Count: 1013
[2021-03-08 16:22:53]
User716258 - Posts: 7
I have a couple feeds using two different charting platforms -- one with you, the other through a prop firm. I use 610 tick charts on both. Denali's feed is slower compared to CQG. CQG's move up and down constantly -- quite quick. Whereas Denali's does not. What ends up happening is that I see bars form differently. Is this "slowness" inherent to Denali? Or is there something I need to do on my end to configure SierraChart correctly? I've read all of the instructions in setting up Denali, and it's working. It just seems like Denali's feed "consolidates" tick data and doesn't actually send true tick data.
Thanks! Love SC!
[2021-03-08 17:05:20]
No this definitely cannot be true:
Refer to:
Prices / Data Falling Behind: 4.2 - Chart Update Interval Too High
Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
And refer to:
Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent
Date Time Of Last Edit: 2021-03-08 17:13:28
[2021-03-08 17:25:26]
Awesome. It was the chart update interval. Thanks so much!
