Date/Time: Mon, 24 Feb 2025 09:36:29 +0000
Notes in Logs
View Count: 480
[2021-03-08 16:08:08]
EuropeanTrader - Posts: 290
is it possible to add notes in the Trade activity log after(!) the trades are done and logged?
Please see the screenshot.
Thank you!
Greg
imageSH_ 9021 Mar. 08 17.07.jpg / V - Attached On 2021-03-08 16:07:58 UTC - Size: 222.79 KB - 217 views
[2021-03-08 17:48:24]
John - SC Support - Posts: 38116
Yes, just select the particular entry you want to modify and select Edit >> Edit Trade Activity Entry, then enter the information you want for the Note field. Refer to the following:
Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log)
