Date/Time: Thu, 19 Sep 2024 21:36:28 +0000
Pullback with ACSIL
View Count: 1435
[2014-02-28 20:09:21] |
Moti - Posts: 63 |
Hi Is it Possible to get the data off the top and the bottom pullback of previous bars with ACSIL? Thank you, |
[2014-03-01 03:02:07] |
vegasfoster - Posts: 444 |
Unless someone else understands, can you post a pic?
[2014-03-01 07:31:46] |
Zosimus - Posts: 345 |
@vegasfoster, I think what this post refers to is the High/Low Pullback Ask/Bid Vol Diff values as they appear on the Numbers Bars Calculated Values Study. @Moti, is that correct ?
[2014-03-01 07:39:49] |
@Moti, I think this data can be approached with sc.HistoricalHighPullbackVolumeAtPriceForBars and sc.HistoricalLowPullbackVolumeAtPriceForBars BUT I read somewhere that this will only give you the Pullback data for the last bar. Anyone knows about this ?
[2014-03-01 08:29:29] |
@Moti, I found this thread which refers to your question. https://www.sierrachart.com/supportboard/showthread.php?p=232945 However I am not sure that I understand the sentence "For the live data (PullbackVolumeAtPrice), always pass index of zero instead of sc.Index. This is because that vap container only holds a single bars worth of data." that appears on post #56. |
[2014-03-01 09:52:13] |
This data is available. Here are the ACSIL members to access it: https://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scHistoricalHighPullbackVolumeAtPriceForBars Pullback data is provided for the historical bars in the chart. The documentation is the master reference for how to work with these arrays. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-01 09:53:03
[2014-03-01 10:59:17] |
Moti - Posts: 63 |
Thank you All. Moti |
[2014-03-01 11:41:43] |
Thanks Yon :-)
