Date/Time: Tue, 29 Sep 2026 00:08:18 +0000
Trading on Eurex via Sierra Chart
View Count: 1630
| [2021-03-08 14:36:29] |
| User206920 - Posts: 28 |
Hello, what would be the best way right now if I want to trade Eurex markets (Bund, FESX) and execute trades directly via Sierra Chart? I have seen Amp reduced options for Sierra connections so is there any other go-to brokerage right now or what is the best solution? It is all a bit confusing for Eurex traders.
| [2021-03-10 07:51:28] |
| [2021-03-10 08:03:26] |
| User657945 - Posts: 226 |
+1 please we cannot stay in stand by forever
| [2021-03-12 05:37:02] |
We apologize for the delay. We are looking into some other options for EUREX trading. We will have someone follow up with you with more information when we have it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-12 05:37:26
| [2021-03-12 07:16:36] |
And what is the option now?
| [2021-03-12 07:38:50] |
thx SC
| [2021-03-12 15:21:31] |
We are still checking on this.
| [2021-03-12 19:37:00] |
| SC Support - Posts: 2105 |
We expect to have to have some guidance on this before the end of the day today. Thank you for your patience.
| [2021-03-12 20:43:08] |
Thx SC, we are like thirsty in the desert right now:)
| [2021-03-14 09:14:21] |
We expect to have to have some guidance on this before the end of the day today. Thank you for your patience. any update? |
| [2021-03-16 16:10:13] |
Hi Guys, at this point we are still having conversation with Brokers about supporting TT (FIX) Order Routing to the EUREX: Britannia Global Markets Limited supports the TT (FIX) Order Routing Service for EUREX Futures, but with a minimum Futures Trading Account balance of $50,000 -- if you are interested in this we can provide you with the contact information. More later. |
| [2021-03-16 20:46:11] |
not so lucky but please help it's one months that we can't auto trade and today I saw a CQG problem, that friendly speaking I did anticiapte in some comments due to way their solution is made. thx
| [2021-03-16 21:01:57] |
Hi User657945, regarding "I saw a CQG problem, that friendly speaking I did anticipate in some comments due to way their solution is made. thx" -- did you share those views with your broker? |
| [2021-03-16 21:05:38] |
Shame, sending 50k to Britannia Global Markets is not an optimal solution. I currently use tradovate and their Dom to execute trades but I really do enjoy the full-depth you guys provide so hopefully you will come up with some solution soon.
| [2021-03-17 08:39:05] |
I shared in some comments here on forum regarding the brackets orders server side and with more than one broker searching for an alternative to AMP (that was fine) to trade with You, I did close the AMP account I can't leave 11K$ just for fun. CQG web api my opinion, but it's notonly mine, it's bull shit. We need a solution to trade eurex I/we can't wait any longer or put 50K$ to an account to follow SC. One thing is to appreciate your software and I do, another is to follow you what ever it takes. Date Time Of Last Edit: 2021-03-17 14:22:50
| [2021-03-23 13:47:51] |
we are now at 23 march and no answer from your side yet...please clarify if it will be an acceptable solution (not a 50k$ account) to connect sierra and safely trade Eurex or not.thx |
| [2021-03-23 14:00:05] |
Have you told AMP that you believe that their connection to EUREX via CQG is "not safe"?
| [2021-03-23 14:52:16] |
I did close the account and I "wrote" to them that the reason was because of the CQG connection.
