Date/Time: Mon, 25 Nov 2024 19:38:08 +0000
Discrepancy between chart and trade dom
View Count: 1094
[2014-02-28 19:54:57] |
madra - Posts: 109 |
Hello, doing Sim trading currency pairs. I notice there is discrepancy between the PL on the chart and on the trade Dom. Have I some setting wrong? For examples the chart reads PL - 0.5009p Chart and trade dom PL + 1.50059p Chart PL -0.5009 p PL Dom 1.4991 p Madra |
[2014-02-28 23:03:11] |
Refer to this help topic 77: http://www.sierrachart.com/index.php?l=doc/helpdetails77.html And update Sierra Chart to the current version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-28 23:03:28
[2014-03-03 23:49:10] |
Thanks for response but still having problems. Tried to follow directions from help topic #77 There is a P/L format in the TAL that I cannot change: it has currency value (C) This is grayed so I can't change to points. Is this the problem? Madra |
[2014-03-04 00:28:59] |
Help topic 77 provides all of the relevant information. The only other possibility is maybe you do not have the Simulation Fills Source set the same between the 2 charts: https://www.sierrachart.com/index.php?l=doc/doc_TradeMenu.html#SimulationFillsSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-04 02:47:32] |
Thanks, back on the 'pigs back' Chart Settings> apply global symbol settings Did this for each chart and problem resolved all the best, Madra |
