Date/Time: Mon, 24 Feb 2025 07:21:55 +0000
Point & Figure Bar is not displaying the OHLC option correctly
View Count: 456
[2021-03-08 00:59:56] |
MMX - Posts: 119 |
I want my Point & Figure chart to display bars rather than the X's and O's. You've made it very clear numerous times in the P&F documentation that the newer Point & Figure Bar is better than the P&F study. In the Graph Draw Type box I've selected OHLC, I've selected HL, and what you get is hardly recognizable as a P&F chart. Frequently you'll have 2 or 3 blue bars in a row, 2 or 3 red bars in a row, P&F is supposed to consistently alternate between the 2 colors. Also, when choosing the OHLC draw type, you don't get the "rounding" off of the highs and lows, like in a congestion, where the tops of 4 blue bars are identical, the bottoms of 4 red bars are identical, what gets displayed instead is just an everyday bar chart with minor differences in the highs and lows of the congestion. Neither one of these issues occur when you are using the Point & Figure Bar with the Point and Figure XO draw type selected. I'm presently using the P&F study, but I'd much rather be using the one that's "highly recommended" "more efficient" "more accurate". Thanks.
[2021-03-08 10:31:22] |
Sierra_Chart Engineering - Posts: 18541 |
In the next release there will be a Point and Figure Bars Graph Draw Type in Chart Settings to do what you want.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-08 10:31:37
