Date/Time: Mon, 24 Feb 2025 07:11:22 +0000
SSD Drive..
View Count: 594
[2021-03-08 00:17:39]
User750920 - Posts: 280
Hi, for Sierra Chart what is the best SSD interface to use. Would I get a lot more speed out of the PCIe versus SATA or would SATA be adequate. Looking to upgrade but I do not believe in buying more than I need unless it would make a difference. Thank you.
[2021-03-08 00:21:15]
Sierra_Chart Engineering - Posts: 18541
You really do not have to ask us. Rely on the information already published as to what is going to be the fastest interface. You absolutely want to get the very fastest. It will make a difference. And it will be noticeable.
Date Time Of Last Edit: 2021-03-08 00:21:37
