Date/Time: Mon, 24 Feb 2025 07:14:29 +0000
RTH Study on Sunday ETH charts
View Count: 705
[2021-03-07 23:25:37] |
User292326 - Posts: 13 |
I have a weekly pivots study that uses RTH sessions to determine its levels. However, I will trade these levels on an ETH chart as well. Right now, When Friday ends and the next sunday globex session begins, my eth charts keep showing the previous weeks pivots on sunday and dont adjust to the current weeks pivots until the RTH open on Monday. The study i am using on my rth chart is the pivot points variable study with the time period type as weeks and length as 1. I then use the study/price overlay on my eth chart to reference the study from the rth chart. Could you recommend any solution to get the current weeks pivots to start displaying upon the start of the globex session on sunday?
[2021-03-08 10:01:52] |
Sierra_Chart Engineering - Posts: 18541 |
How do you have this setting set? General Settings Window: Use Monday as Start of Week instead of Sunday (Global Settings >> General Settings >> General >> Data) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-08 15:06:32] |
The box is currently unchecked for "Use Monday as Start of Week instead of Sunday"
