Date/Time: Mon, 24 Feb 2025 07:09:20 +0000
What symbol should I Enable for market depth download Using IB + Barcharts data feed.
View Count: 937
[2021-03-07 23:21:28]
GravisHTG - Posts: 306
In real time , I can get some Data from the Last Bid/Ask. I would love to be able to access it after or on any charts.
I look into your self help page and find out that you need to enable the feature for each Symbol.
After looking in Global Settings/Symbol Settings. I wonder what Symbol I should enable the Record Market Depth data and does the Number of depth levels to subscribe matter ?
fact to add.
I just order the Data for market depth with IB ( dont thinnk it will change something ) and I dont have any market depth with you.
the 2 picture are some symbol i think i should enable the market depth. Not sure.
imagesymbol1.PNG / V - Attached On 2021-03-07 23:21:14 UTC - Size: 9.42 KB - 188 views
imagesymbol2.PNG / V - Attached On 2021-03-07 23:21:19 UTC - Size: 11.92 KB - 204 views
[2021-03-07 23:31:23]
Sierra_Chart Engineering - Posts: 18541
There is no historical market depth data supported for the US equities exchange on the Sierra Chart Exchange Data Feed.
[2021-03-07 23:34:00]
ok , But when i am live , I can have some data, The data from the LAST BID ASK and it plot the market depth historical graph on chart.
How can I keep that data at least ?
Date Time Of Last Edit: 2021-03-07 23:35:11
[2021-03-08 03:17:34]
and what is the difference between the ???? and the ??? and the ?? and ? -stk-arca... Symbol in symbol settings
see picture for more info
Date Time Of Last Edit: 2021-03-08 03:19:36
imagesymbol3.PNG / V - Attached On 2021-03-08 03:19:34 UTC - Size: 12.31 KB - 173 views
