Date/Time: Mon, 24 Feb 2025 06:32:36 +0000
Question about CQG data and Package 3
View Count: 697
[2021-03-07 22:55:46]
User752602 - Posts: 9
Is service package 3 able to work with CQG data? There's been some back and forth over the last few weeks whether this is supported.
I'm with AMP and I would like to stick with CQG for now, as it's always been fine for me.
Also, I have no problem with paying as i've used your software since 2013. Can you tell me the reason AMP customers are switched for March and not April 1?
I have had no communication from AMP at all in regards to the change. Thanks again for the great software.
[2021-03-07 23:07:25]
In your case the reason you would have to begin paying in March is because you logged into Sierra Chart late in the month. It is a special case.
You just need to follow the instructions here:
Notice: Transition to Direct Sierra Chart Billing For SC Accounts through Broker
Date Time Of Last Edit: 2021-03-07 23:07:41
[2021-03-07 23:21:32]
No problem, understood.
In regard to my other question. Does service package 3 support CQG data at this time?
[2021-03-07 23:30:18]
Sierra_Chart Engineering - Posts: 18541
The answer is yes to that.
