Date/Time: Mon, 24 Feb 2025 06:00:47 +0000
New Sierra packages
View Count: 802
[2021-03-07 21:49:18] |
User516084 - Posts: 13 |
What package do I need? I previously had service package 5 with Denali data. It looks like I renewed for this month with the same service pack 5. Does this mean I don’t get Denali data feed? Should I switch to service pack 12? Then re-add the exchanges of my choosing? Will I be prorated for the 2 days used? I thought this would automatically changed me to the similar package.
[2021-03-07 22:20:15] |
You will want to use Service Package 11 which does include the Denali Exchange Data Feed. You can set that here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation And then you can also activate exchanges from that same page. Information about changing Service Package: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
