Date/Time: Mon, 24 Feb 2025 06:16:01 +0000
Data/Trade Service Settings Window
View Count: 996
[2021-03-07 05:57:54] |
User923359 - Posts: 4 |
Why does my data/trade service settings window show this? All the instructions on the SierraChart website show a different window.
Attachment Deleted. ![]() |
[2021-03-07 13:29:53] |
58LesPaul - Posts: 429 |
I believe some time in the past they changed the way those windows look in the software and never updated the documentation. I see the same thing in a few other windows also.
[2021-03-07 14:39:47] |
Here is the documentation for the new Settings Windows: Settings Windows Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-07 15:09:02] |
aknsyu71@gmail - Posts: 54 |
This has not improved the user experience, to the contrary, it makes adjusting settings more difficult. Please can you inlude an option for the user to decide wheter to use the new syle settings window or the old style which in my opinion is a lot clearer. |
[2021-03-07 15:52:45] |
Absolutely not. Under no circumstances would there be support for the old ones. These new ones have a superior stable implementation compared to the Microsoft garbage we were using before. Please just get used to them. We will gradually improve them as needed. We have had enough of this Microsoft garbage trash. Those old dialogs are history and they are going to be fully gone as soon as possible. What we probably will do is move the Common Settings on the Data/Trade Service Settings window to the first tab. And that should make everything easy to find on the first tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-07 15:58:12
[2021-03-07 17:13:11] |
We will move the Time Zone setting to a separate settings window altogether and move Common Settings to the Main tab.
