Date/Time: Sat, 12 Sep 2026 08:18:52 +0000
various questions regarding acct setup, data, etc...
View Count: 807
| [2021-03-06 13:51:22] |
| User735389 - Posts: 189 |
I recently switched to IB, trading both stocks and futures. Its been fine so far, but have a few additional questions: 1. I'm currently using IB with SC Data for stocks, and IB for futures. I saw today that i can get full historical futures data with level 5 package. If i wanted to just go all SC for stock and futures data (denali), would it all integrate in one instance sierrachart, or would i have to run 2 different instances of sierrachart? 2. What would be the cost of this? 3. I notice SC Data has access to coins data, but those symbols are not available when i connect to IB to actually trade. Is there a way to make SC Data symbols available for viewing when im connected to IB? thanks |
| [2021-03-08 15:24:48] |
| John - SC Support - Posts: 47854 |
1. You could get the data from us and trade with IB through one instance of Sierra Chart. You would need to change to Package 10 (not 5). 2. The cost would be the following: - Package 10: $36.00 USD per month ($10 additional) - CME Exchange Fees: Various - Sierra Chart Exchange Data Feed (250 Symbols): $25.00 USD per month - U.S. Equities Exchange: $10.50 USD per month 3. The easiest way to do this is to have a second instance of Sierra Chart that has the Service Set to SC Data - All Services. There is no additional fees to do this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-18 14:30:33] |
3. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
