Date/Time: Mon, 24 Feb 2025 07:15:25 +0000
Divergence Volume in Historical and Intraday Chart
View Count: 598
[2021-03-06 11:29:45] |
User103448 - Posts: 76 |
Hello, im wondering why there is a difference in Total Volume of the Day when using Historical and Intraday Chart. Could you explain the calculation mode? |
[2021-03-08 15:01:19] |
John - SC Support - Posts: 38116 |
Refer to the following: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
