Date/Time: Mon, 25 Nov 2024 18:21:38 +0000
Bringing prior trades into Trade Activity Log
View Count: 1211
[2014-02-28 17:48:41]
User33552 - Posts: 23
Trading with Infinity.
I had some trades this month prior to purchasing Sierra Charts and it would be helpful to be able to see those prior trades in Trade Activity Log.
How can I import or manually enter them into the Trade Activity Log?
Thank you.
[2014-02-28 19:34:16]
You can manually enter them through the Edit menu on the Trade >> Trade Activity Log. Here is the documentation for this:
http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#MenuCommands
[2014-03-02 00:58:33]
Thank you....but the trades don't show up in "Trade Activity."
I entered 2 trades. They both show in "Trades tab. Neither shows in the Trade Activity tab.
Shouldn't they?
I need to modify one of the trades I entered. The Edit option is not available in Trades tab and the trades are not showing in Trade Activity tab so I can neither edit nor delete the trade.
How can I edit a trade I entered in Trades tab?
How can I delete a trade I entered in Trades tab?
[2014-03-03 00:56:56]
If you see them in the Trades tab they must absolutely be listed the Trade Activity tab. There is no other possibility of that. If not, then what you are seeing on the Trades tab must be originating from other fills that you see in the Trade Activity tab.
You can only edit the order fills displayed on the Trade Activity tab. And the Trades tab, only consists of Trades generated from the displayed order fills on the Trade Activity tab. This is 100% certain.
[2014-03-03 13:24:03]
Thank you, but they are not showing up...unless there is a setting that is causing them not to show.
I have attached screenshots of Trades tab and of Trade Activity tab for you to see.
As you see, the Trades shows a trade on 2-6, the first trade on Trade Activity is 2-19. The Date Range to Displayis set to start at 1-1-2014.
In addition, There is a screen shot of Trade Statistics that does show the 2-6-14 trade in the stats portion.
attachmentTrade Activity not showing manual entries.doc - Attached On 2014-03-03 13:22:34 UTC - Size: 94.5 KB - 369 views
[2014-03-03 16:52:20]
At the top left of the Trade Activity Log, select Fills or All Activity.
Date Time Of Last Edit: 2014-03-03 16:52:41
