Date/Time: Wed, 27 Nov 2024 16:32:30 +0000
[User Discussion] - 238:5: error: 'CalculateDailyOHLC' was not declared in this scope
View Count: 866
[2021-03-06 02:53:37]
InvestmentCLB - Posts: 11
I copied and pasted the source code (DailyOHLC) in a custom study I'm working on. For the oddest reason, the code will not compile (remote build). This is the error message I'm receiving below:
MarketProfileAlertingSystem.cpp: In function 'void scsf_DailyOHLC(SCStudyInterfaceRef)':
MarketProfileAlertingSystem.cpp:238:5: error: 'CalculateDailyOHLC' was not declared in this scope
238 | CalculateDailyOHLC(
-- End of Build -- 20:37:05
Can someone help me? Thanks.
[2021-03-08 17:01:38]
User139950 - Posts: 4
Copy the CalculateDailyOHLC from scstudyfunctions.cpp to your cpp. Maybe it's enough when you include scstudyfunctions.h.
[2021-03-10 23:44:24]
Hello, User139950
Were do I find scstudyfuntion instead of scstudyInterfaceRef to copy from? Thanks.
Date Time Of Last Edit: 2021-03-10 23:47:06
[2021-03-11 00:59:54]
Flipper_2 - Posts: 57
You should post your code so someone can easily repeat the error and help easily.
[2021-03-11 02:14:17]
Ackin - Posts: 1865
MrRoy)
compiling error scstudyfunctions.h
[2023-07-22 06:06:45]
Ed C. - Posts: 117
Is there a replacement for CalculateDailyOHLC()? Some days it gives correct data, others it doesn't. Thanks, all!
[2023-07-22 08:59:06]
User431178 - Posts: 544
Are you sure?
The same function is used in study 'Daily OHLC', which can be found studies8.cpp, that study seems to work ok.
[2023-07-24 23:00:43]
Ed C. - Posts: 117
Are you sure?
Unfortunately, yes. A study from 2020 and one compiled several days ago gives different results. The old CalculateDailyOHLC() function and the new one are also different in the number of function arguments, so something must have changed.
