Date/Time: Mon, 24 Feb 2025 06:25:53 +0000
have you changed some coding in the past year?
View Count: 655
[2021-03-06 00:50:26] |
Devil_On_WallStreet - Posts: 67 |
I took a break from trading for about a year... now getting errors left and right... here is a sample of code that I am getting errors on #int& BullState = sc.PersistVars->i1; other errors it looks like it wants me to add in a "std::" this would be what the 2nd or 3rd time that coding has been changed with no support of running older code!!! is there a page that goes over EVERYTHING changed? Date Time Of Last Edit: 2021-03-06 01:15:49
[2021-03-06 07:27:04] |
The changes are documented here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php The persistent variables that you show, have been removed many years ago and replaced with functions for persistent variables. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-06 17:37:27
