Date/Time: Mon, 24 Feb 2025 06:02:26 +0000
Re-installation
View Count: 483
[2021-03-05 19:38:03] |
58LesPaul - Posts: 429 |
I am currently running SC on a Mac using Parallels. As you know I had to install Windows 10. I think I would be better off using CodeWeaver Crossover which I won’t have to install the complete Windows OS and leave my computer to run better. Since I am not a computer geek could someone recommend how to go about removing Windows and Parallels most effectively? As far as SC, I can see in the documentation what to backup, will it matter that it’s backed up using Windows on a Mac? Will all the files transfer correctly going from Windows to an SSD drive for Mac and then back on the Mac using Crossover? Thanks |
[2021-03-05 23:48:35] |
Here is the relevant documentation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation We do not think it matters what operating system you are using to do the backup and we do not think there is any problem with the file transfer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-03-05 23:48:40
