Date/Time: Thu, 19 Sep 2024 21:57:33 +0000
order status request failed - error
View Count: 1321
[2014-02-28 17:00:02] |
M5amhan - Posts: 468 |
Hi, When I am placing orders through TD Ameritrade (not using SC), I get this pop up message on SC even though I am not using it. I tried turning on sim mode but it still pops up when I am placing orders on thinkorswim. Is it possible to make this go away? Date Time Of Last Edit: 2014-02-28 17:12:28
Capture.PNG / V - Attached On 2014-02-28 17:12:25 UTC - Size: 32.97 KB - 342 views |
[2014-02-28 18:26:39] |
No it is not possible to make it go away. Contact TD Ameritrade and ask them why this is happening. The text of the message which is after "Error:" is from TD Ameritrade. This is in response to the status of an order being requested by Sierra Chart from the TD Ameritrade system using their HTTP API. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-28 18:27:37
