Date/Time: Mon, 24 Feb 2025 06:07:56 +0000
would like to authorize CME package
View Count: 433
[2021-03-05 15:12:06] |
MightyTulip - Posts: 5 |
Hi, I would like to authorize order routing through CQG to AMP Futures on my account. my charts say 'symbol unknown'. I have a username and password for CQG WEBAPI. I called AMP futures to authorize cqg order routing but they told me that I needed to contact you directly. I am not sure how to do it other than a support ticket. Thanks!
[2021-03-05 15:54:15] |
John - SC Support - Posts: 38116 |
The first thing is to make sure that you have setup your Sierra Chart to connect to your CQG account. Follow the instructions here: CQG Trading Platform Service: Setup Instructions After you have completed the above, select "Edit >> Translate Symbols to Current Service" to translate any already open charts to the CQG symbols. Refer to the following: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
