Date/Time: Fri, 25 Sep 2026 18:59:48 +0000
[Programming Help] - Array Statistics and functions
View Count: 981
| [2021-03-05 14:30:22] |
| grantx - Posts: 244 |
Are there any ACSIL functions to work out things like MAX, MIN, MEDIAN, IQR, SORT (highest to lowest etc..)? There are functions in the spreadsheet study but they can't be used in ACSIL. Or can they? Date Time Of Last Edit: 2021-03-05 14:32:01
| [2024-01-30 19:42:44] |
| User411320 - Posts: 377 |
did you ever find out
| [2024-01-31 18:23:54] |
| User43 - Posts: 102 |
All ACSIL stock functions are documented in ACSIL Interface Members - Functions min ACSIL Interface Members - Functions: min() max ACSIL Interface Members - Functions: max() I think median would be ACSIL Interface Members - Functions: sc.MovingMedian() I don't think there is a IQR or SORT function But at the end of the day you have the whole power of C / C++ at your fingertips where you can write your own functions as needed. You can also via ACSIL interact with Spreadsheets. |
| [2024-02-01 08:48:14] |
| User719512 - Posts: 482 |
Expanding on what user43 says, I'd take whatever values you are looking at, put them in a std::list and write functions to operate on a list to find your desired calculations. From there you could optimize once it's working if perf an issue.
