Date/Time: Mon, 24 Feb 2025 06:27:18 +0000
Combining columns/candelsticks within Numbers Bars Study
View Count: 642
[2021-03-05 13:26:42]
IC2021 - Posts: 8
Hope you're doing well :)
Please see the attached photo.
So, I've managed somehow to create 2 identical candles with different coloring method. is there any way to combine both candles into one candlestick?
i.e transfer the red and green numbers numbers(imbalances) from the right hand side candlestick into the left hand side candlestick.
Thanks!
Date Time Of Last Edit: 2021-03-05 13:32:30
imagesierra.PNG / V - Attached On 2021-03-05 13:26:07 UTC - Size: 105.31 KB - 201 views
[2021-03-05 15:38:29]
John - SC Support - Posts: 38116
You have turned on the data for Column 1 and Column 2. Just turn off the display for Column 2 (set "Column 2 Numbers Bars Text" to "None") and then set the "Column 1 Text Coloring Method" to what you want.
