Date/Time: Sun, 26 Jan 2025 18:18:47 +0000
Back adjustment malfunction on rollover
View Count: 534
[2021-03-05 12:23:18]
Oceans - Posts: 12
I set the FGBLH21-EUREX [CBV][M] chart to Continuous Futures Contract - Volume Based Rollover Back Adjusted.
Today, for the first time since I use Sierra Chart, the platform suggested to perform the rollover based on volume.
So I did, choosing the next contract (FGBLM21).
Now there is a huge rollover gap.
I followed all the instructions on this link: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data
but I'm still unable to fix the gap.
I look forward to your kind response
[2021-03-05 13:31:10]
We do see this problem. It is because there is no historical Daily data available yet for EUREX from our data provider for March 5, 2021. We have to think about a solution to this.
However, the problem will clear up by the end of the day. At that time reload the chart with Chart >> Reload and Recalculate.
[2021-03-19 11:35:21]
Oceans - Posts: 12
today the stock indexes Eurex futures' rollover is due (3rd Friday of the contract month, as correctly stated in the Symbol Settings).
So I performed the rollover on the following contracts:
- FDAXH21-EUREX[M] ---> FDAXM21-EUREX[M]
- FESXH21-EUREX[M] ---> FESXM21-EUREX[M]
Everything is fine with FDAX, both using volume based and date based back-adjusted criteria.
With FESX there is a problem:
- if I choose volume based back-adjusted criteria there is no rollover gap but the rollover is performed on March 18 instead of March 19
- if I choose date based back-adjusted criteria the rollover date is fine (March 19) but there is a rollover gap (no back-adjustement)
I guess the problem is related to the one I signaled in my previous post.
[2021-03-19 14:29:21]
Sierra_Chart Engineering - Posts: 18122
This is what we see:
http://www.sierrachart.com/image.php?Image=1616163911313.png
We want you to update to the current version:
And then follow the instructions here if there is any further issue:
