Date/Time: Mon, 25 Nov 2024 19:57:16 +0000
IQ Data Feed
View Count: 1082
[2014-02-28 15:44:51] |
User15279 - Posts: 2 |
There is a problem with IQ data feed. For the TPO chart, the price is running up and down, but the red triangle is not moving. So the letter doesn't print on TPO chart. But IB data is fine.
[2014-02-28 18:33:53] |
Open a new chart for the symbol of that chart you are having a problem with and see if there is the same problem. The relevant help topic for this is 3: https://www.sierrachart.com/index.php?l=helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
