Date/Time: Mon, 24 Feb 2025 06:18:41 +0000
Synchronizing text between several charts
View Count: 420
[2021-03-04 20:58:11] |
User645832 - Posts: 99 |
Is it possible?
Date Time Of Last Edit: 2021-03-08 10:22:06
[2021-03-04 21:32:52] |
John - SC Support - Posts: 38116 |
We do not know what exactly you are asking. Perhaps you are referring to copying text drawings, in which case refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
