Date/Time: Sun, 20 Sep 2026 12:12:37 +0000
Getting started
View Count: 1195
[2021-03-04 18:57:31]
User683355 - Posts: 13
Totally lost with a broker not having its on platform. How do I link Sierra Charts to my broker? How do I open up live Sierra charts and begin to live trade? HELP please
[2021-03-04 19:20:40]
John - SC Support - Posts: 47939
Who is your broker? If applicable, do you know what trading service they have you setup to use?
[2021-03-04 19:22:24]
I am trying to set up my account thru AMP
Trading service?
[2021-03-04 19:48:26]
Since you are using AMP, they should set you up with CQG for your order routing. Once you receive the CQG credentials from AMP, then you will go through the Setup Instructions at the following link to connect your Sierra Chart software to your CQG account:
CQG Trading Platform Service: Setup Instructions
After that, if you want Real-Time data from us, then you would use the Denali Exchange Data Feed for CME Group and EUREX data. Refer to the information and Setup Instructions on this page:
[2021-03-04 20:32:15]
Where could I find a commission and fee schedule? Tick value chart?
[2021-03-04 21:21:07]
You have to ask AMP for the Commission and Fee Schedule.
With regards to a Tick Value Chart, we assume you are asking how to create this chart. You would need to set the Bar Period Type to Number of Trades and then enter 1 for the actual number. Refer to the information starting here:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar
[2021-03-05 14:35:47]
No that is not what I mean. What I am looking for is the actual monetary value of one tick on each of the symbols.
Example: if ES goes from 3797.00 to 3797.25, what does that equal in dollar terms.
David
[2021-03-05 15:19:21]
The lack of customer support is AMAZING in todays market.
[2021-03-05 16:00:16]
Refer to the following setting:
Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
[2021-04-07 16:09:32]
Why is it so difficult to do anything on this site? I am a customer of AMP. When I originally signed up with AMP, the Sierra Charts package 3 was free. Now it is not. How to I sign up for package 3? It seems like it should be so easy to give SC my money but I am lost.
[2021-04-07 17:18:21]
The easiest way to add funds to your Sierra Chart account is to select Help >> Add Usage Credit from within your Sierra Chart software. This will open a browser to the Payments page and automatically log you in using the same Account Name and Password that you used to login to the Sierra Chart software.
Otherwise, you can access the Payments page directly through the following link. You will then have to login to the website using the same Account Name and Password that you use to login to your Sierra Chart software.
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
[2021-04-07 17:29:16]
The link that you sent me sends me to a page that needs me to go to "Data/Trade service settings" but I cannot go to that site until I have a membership. Little bit of catch 22 isnt it?
[2021-04-07 18:32:58]
You are logging into this site with an account that you are then posting from. If you want to use that account with your Sierra Chart software, then select the following link and it will take you to the Payments page:
If you are not logged into the Sierra Chart website then log in using the same credentials you are using to login to post to the support board.
[2021-04-08 19:18:04]
How long do I have to wait, after making a payment, do I have to wait before my account is back online?
[2021-04-08 19:32:28]
Once you make a payment then the payment is posted immediately.
But, if your account had been expired, then you would need to manually select the service package that you want, in order to get your account running again.
We see that you have package 5 selected and your account is now active. So you should be all good.
[2021-04-14 15:02:07]
I am having an issue opening charts for ESM and NQM. Please advise.
David
[2021-04-14 15:20:35]
We need more information. What exactly is happening? If you are getting an error message, what exactly does it state?
[2021-04-14 15:27:59]
Under "new/open intraday chart", I type in F.US.ESM12.scid and receive "symbol settings not found for current service". I also receive the same message when I try to open F.US.NQM12.scid. I had no problem opening F.US.YMM21
[2021-04-14 15:34:23]
You have specifically typed in "12" in the symbols that you listed above. Did you type in a "12" when trying to open the symbols instead of a "21"?
[2021-04-14 15:42:07]
No, I put in 21 (oops).
[2021-04-14 15:51:50]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-04-14 15:59:37]
I am trying to open F.US.NQM21, The message I received was currently no data in file to display
[2021-04-14 16:10:08]
Please follow the above instructions to get us your Message Log.
[2021-04-14 16:21:03]
Software version: 2234 64-bit | 2021-04-14 11:56:44.929
Primary Thread ID: 2080 | 2021-04-14 11:56:44.929
Usage end date: 2021-05-09 | 2021-04-14 11:56:44.929
Enabled for: Advanced Features 2. | 2021-04-14 11:56:44.929
Enabled for: Sierra Chart Historical Data Service. | 2021-04-14 11:56:44.929
Enabled for: Delayed Denali Exchange Data Feed. | 2021-04-14 11:56:44.929
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-04-14 11:56:44.929
Current selected Data/Trading service: CQG WebAPI | 2021-04-14 11:56:44.929
Custom symbol settings values: enabled | 2021-04-14 11:56:44.929
Chart Update Interval: 500 | 2021-04-14 11:56:44.929
Intraday Data Storage Time Unit: 1 | 2021-04-14 11:56:44.929
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-04-14 11:56:44.929
2021-04-14 15:56:44 Local computer time in UTC | 2021-04-14 11:56:44.929
2021-04-14 11:56:44 Local computer time in SC Time Zone | 2021-04-14 11:56:44.929
2021-04-12 15:23:00 Server time in UTC | 2021-04-14 11:56:44.929
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-04-14 11:56:44.929
Program path: C:\SierraChart\ | 2021-04-14 11:56:44.929
Data Files path: C:\SierraChart\Data\ | 2021-04-14 11:56:44.929
OS Version Number: 10.0 | 2021-04-14 11:56:44.930
Locale Setting: C | 2021-04-14 11:56:44.930
DLLs: UserContributedStudies_64.dll | 2021-04-14 11:56:44.930
Allowed protected custom studies: | 2021-04-14 11:56:44.930
F.US.ESM21 1 Min #11 | Reloading chart. | 2021-04-14 11:57:22.815
F.US.ESM21 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.ESM21.scid | 2021-04-14 11:57:22.825
File >> Disconnect selected. | 2021-04-14 11:57:30.631
CQG WebAPI | Sending Web API Logoff message. | 2021-04-14 11:57:30.631
CQG WebSocket socket (1) | CloseSocket call. | 2021-04-14 11:57:30.631
CQG WebSocket socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-04-14 11:57:30.631
CQG WebSocket socket (1) | Max send buffers used during socket life: 3 | 2021-04-14 11:57:30.631
CQG WebSocket socket (1) | Max send buffer size during socket life: 340 | 2021-04-14 11:57:30.631
CQG WebSocket | WebSocket closed. | 2021-04-14 11:57:30.631
CQG WebAPI | WebSocket closed. | 2021-04-14 11:57:30.631
CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-04-14 11:57:30.631
CQG WebAPI | Disconnected. | 2021-04-14 11:57:30.632
CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-04-14 11:57:30.680
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-04-14 11:57:30.680
CQG WebAPI | Connecting to server api.cqg.com | 2021-04-14 11:57:34.177
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-04-14 11:57:34.177
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-04-14 11:57:34.312
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-04-14 11:57:34.312
CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2021-04-14 11:57:34.312
CQG WebSocket | Opening WebSocket. | 2021-04-14 11:57:34.372
CQG WebSocket | Sending WebSocket handshake. | 2021-04-14 11:57:34.372
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-04-14 11:57:34.565
CQG WebSocket | Server header | Connection: upgrade | 2021-04-14 11:57:34.565
CQG WebSocket | Server header | Sec-WebSocket-Accept: XVGGQqihQgoLMjlvxfmfsRDXVIo= | 2021-04-14 11:57:34.565
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-04-14 11:57:34.565
CQG WebSocket | Server header | Upgrade: websocket | 2021-04-14 11:57:34.565
CQG WebSocket | Server header | | 2021-04-14 11:57:34.565
CQG WebSocket | Web socket state is now open. | 2021-04-14 11:57:34.565
CQG WebAPI | WebSocket connected. | 2021-04-14 11:57:34.565
CQG WebAPI | Sending market data logon message. | 2021-04-14 11:57:34.565
CQG WebAPI | Base Time: 2021-04-11T21:43:53. 2021-04-11 21:43:53 | 2021-04-14 11:57:34.741
CQG WebAPI | Logon successful. Session Token = AdDLGuOlGpc3gMJbg5tiqNKzomztnkG4MY2ixn6LEEIAe/T28zKCQUC9jut5H2v2i2vlY9fYfQo | 2021-04-14 11:57:34.741
CQG WebAPI | Connected to server complete. | 2021-04-14 11:57:34.741
Triggering next historical data download in queue. | 2021-04-14 11:57:34.742
Updated verified funded futures trading account ending date to: 2021-05-14 15:57:34 | 2021-04-14 11:57:34.742
CQG WebAPI | Sending Trade Accounts request message. | 2021-04-14 11:57:34.742
No download requests in the queue to start downloads for. | 2021-04-14 11:57:34.742
CQG WebAPI | Starting real-time market data updates for: F.US.ESM21. ID: 1 | 2021-04-14 11:57:34.803
CQG WebAPI | Sending symbol resolution request for F.US.ESM21. ID: 122780 | 2021-04-14 11:57:34.803
CQG WebAPI | Requesting security definition data for: F.US.ESM21. ID: 1 | 2021-04-14 11:57:34.803
CQG WebAPI | Using primary service for historical data for F.US.ESM21 | 2021-04-14 11:57:34.803
Added historical Intraday data request for F.US.ESM21 to the queue. | 2021-04-14 11:57:34.803
Intraday data recording state for symbol F.US.ESM21 is set to download 'Pending'. | 2021-04-14 11:57:34.803
Triggering next historical data download in queue. | 2021-04-14 11:57:34.803
Delaying start of download for F.US.ESM21 | 2021-04-14 11:57:34.804
CQG WebAPI | Starting real-time market data updates for: F.US.YMM21. ID: 2 Service code: cqg | 2021-04-14 11:57:34.809
CQG WebAPI | Sending symbol resolution request for F.US.YMM21. ID: 122781 | 2021-04-14 11:57:34.809
CQG WebAPI | Requesting security definition data for: F.US.YMM21. ID: 2 | 2021-04-14 11:57:34.809
CQG WebAPI | Using primary service for historical data for F.US.YMM21 | 2021-04-14 11:57:34.809
Added historical Intraday data request for F.US.YMM21 to the queue. | 2021-04-14 11:57:34.809
Intraday data recording state for symbol F.US.YMM21 is set to download 'Pending'. | 2021-04-14 11:57:34.809
Triggering next historical data download in queue. | 2021-04-14 11:57:34.809
CQG WebAPI | Brokerage name: AMP. Account Name: 138461 | 2021-04-14 11:57:34.851
CQG WebAPI | Sending collateral subscribe request. | 2021-04-14 11:57:34.851
CQG WebAPI | Received symbol resolution report for symbol F.US.ESM21. Search Symbol: F.US.ESM21. Request ID: 122780. Contract ID: 1. | 2021-04-14 11:57:34.862
CQG WebAPI | Requesting market data for F.US.ESM21 | 2021-04-14 11:57:34.862
CQG WebAPI | Received symbol resolution report for symbol F.US.YMM21. Search Symbol: F.US.YMM21. Request ID: 122781. Contract ID: 2. | 2021-04-14 11:57:34.868
CQG WebAPI | Requesting market data for F.US.YMM21 | 2021-04-14 11:57:34.869
CQG WebAPI | Starting real-time market data updates for: F.US.nqm21. ID: 3 | 2021-04-14 11:57:34.963
CQG WebAPI | Sending symbol resolution request for F.US.nqm21. ID: 122783 | 2021-04-14 11:57:34.963
CQG WebAPI | Requesting security definition data for: F.US.nqm21. ID: 3 | 2021-04-14 11:57:34.963
CQG WebAPI | Using primary service for historical data for F.US.nqm21 | 2021-04-14 11:57:34.963
Added historical Intraday data request for F.US.nqm21 to the queue. | 2021-04-14 11:57:34.963
Intraday data recording state for symbol F.US.nqm21 is set to download 'Pending'. | 2021-04-14 11:57:34.963
Triggering next historical data download in queue. | 2021-04-14 11:57:34.963
CQG WebAPI | Market data subscription for F.US.ESM21 was unsuccessful. Text: Real-time data for instrument F.US.ES (corresponding to ID = 1) are not allowed. | 2021-04-14 11:57:34.972
Symbol Error - F.US.ESM21 is unknown, unavailable, or improperly formatted. Real-time data for instrument F.US.ES (corresponding to ID = 1) are not allowed. | 2021-04-14 11:57:34.972
CQG WebAPI | Received message: Requested symbol was not found. | 2021-04-14 11:57:35.025
Symbol Error - F.US.nqm21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-04-14 11:57:35.025
CQG WebAPI | Starting real-time market data updates for: ESM21. ID: 4 | 2021-04-14 11:57:35.103
CQG WebAPI | Sending symbol resolution request for ESM21. ID: 122784 | 2021-04-14 11:57:35.103
CQG WebAPI | Requesting security definition data for: ESM21. ID: 4 | 2021-04-14 11:57:35.103
CQG WebAPI | Using primary service for historical data for ESM21 | 2021-04-14 11:57:35.103
Added historical Intraday data request for ESM21 to the queue. | 2021-04-14 11:57:35.103
Intraday data recording state for symbol ESM21 is set to download 'Pending'. | 2021-04-14 11:57:35.103
Triggering next historical data download in queue. | 2021-04-14 11:57:35.103
CQG WebAPI | Received symbol resolution report for symbol F.US.ESM21. Search Symbol: ESM21. Request ID: 122784. Contract ID: 1. | 2021-04-14 11:57:35.159
Symbol Error - ESM21 is unknown, unavailable, or improperly formatted. Exact match not found for symbol ESM21 | 2021-04-14 11:57:35.159
HD Request # 12 | Downloading Intraday chart data for F.US.ESM21 to the file F.US.ESM21.scid. Service: cqg | 2021-04-14 11:57:35.633
HD Request # 12 | Performing multistage download. Downloading Minute data first. | 2021-04-14 11:57:35.634
HD Request # 12 | Download start date-time: 2020-10-10 11:57:35.000000. File last date-time: 00:00:00.000000 | 2021-04-14 11:57:35.634
HD Request # 12 | Disabling Intraday chart updating for symbol. | 2021-04-14 11:57:35.634
HD Request # 12 | Requesting historical Minute data. | 2021-04-14 11:57:35.634
HD Request # 12 | Error downloading historical Intraday data for F.US.ESM21. Instrument F.US.ES (corresponding to ID 1) is not allowed. | 2021-04-14 11:57:35.747
HD Request # 12 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ESM21 | 2021-04-14 11:57:35.747
HD Request # 12 | Completion time: 0s | 2021-04-14 11:57:35.747
HD Request # 12 | Intraday data download complete for F.US.ESM21. Unique request ID: 9 | 2021-04-14 11:57:35.747
Added historical Intraday data request for F.US.ESM21 to the queue. | 2021-04-14 11:57:35.747
Triggering next historical data download in queue. | 2021-04-14 11:57:35.747
HD Request # 13 | Downloading Intraday chart data for F.US.ESM21 to the file F.US.ESM21.scid. Service: cqg | 2021-04-14 11:57:35.747
HD Request # 13 | Rounding start date-time down to the minute: 2020-10-10 11:57:00.000 | 2021-04-14 11:57:35.748
HD Request # 13 | Download start date-time: 2020-10-10 11:57:00.000000. File last date-time: 00:00:00.000000 | 2021-04-14 11:57:35.748
HD Request # 13 | Requesting historical Tick data. | 2021-04-14 11:57:35.748
HD Request # 13 | Error downloading historical Intraday data for F.US.ESM21. Instrument F.US.ES (corresponding to ID 1) is not allowed. Result=103. Num Quotes=0 | 2021-04-14 11:57:35.860
HD Request # 13 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.ESM21 | 2021-04-14 11:57:35.860
HD Request # 13 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2021-04-14 11:57:35.860
HD Request # 13 | Completion time: 0s | 2021-04-14 11:57:35.860
HD Request # 13 | Intraday data download complete for F.US.ESM21. Unique request ID: 9 | 2021-04-14 11:57:35.860
Removing historical data download ID 9. | 2021-04-14 11:57:35.860
Real-time Intraday chart data file updates started for F.US.ESM21 | 2021-04-14 11:57:35.860
Opened cached Intraday file: C:\SierraChart\Data\F.US.ESM21.scid. Thread ID: 2080 | 2021-04-14 11:57:35.860
Intraday chart data file opened for F.US.ESM21 | 2021-04-14 11:57:35.860
HD Request # 13 | Enabling Intraday chart updating for symbol. | 2021-04-14 11:57:35.860
Triggering next historical data download in queue. | 2021-04-14 11:57:35.860
Delaying start of download for F.US.YMM21 | 2021-04-14 11:57:35.860
HD Request # 14 | Downloading Intraday chart data for F.US.YMM21 to the file F.US.YMM21.scid. Service: cqg | 2021-04-14 11:57:39.631
HD Request # 14 | Download start date-time: 2021-04-14 11:57:31.000000. File last date-time: 2021-04-14 11:57:31.000000 | 2021-04-14 11:57:39.631
HD Request # 14 | Requesting historical Minute data. | 2021-04-14 11:57:39.631
CQG WebAPI | Sending positions subscribe request. RequestID: 122788 | 2021-04-14 11:57:39.737
CQG WebAPI | Sending orders subscribe request. RequestID=122789 | 2021-04-14 11:57:39.737
Requesting market depth updates for: F.US.YMM21 if supported. | 2021-04-14 11:57:39.737
CQG WebAPI | Requesting market data including full depth for F.US.YMM21 | 2021-04-14 11:57:39.737
HD Request # 14 | Receiving Intraday data for F.US.YMM21 starting at 2021-04-14 11:57:00.000000 | 2021-04-14 11:57:39.920
HD Request # 14 | Received 1 record from 2021-04-14 11:57:00.000000 to 2021-04-14 11:57:00.000000 (0.0 seconds) and wrote 0 records for F.US.YMM21 | 2021-04-14 11:57:39.921
HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2021-04-14 15:57:31.000000 | 2021-04-14 11:57:39.921
Added 2 Time and Sales records to Intraday data file for F.US.YMM21 after download. | 2021-04-14 11:57:39.921
HD Request # 14 | Timestamp of first Intraday data file record written: 2021-04-14 11:57:38.760000 | 2021-04-14 11:57:39.922
HD Request # 14 | Completion time: 0s | 2021-04-14 11:57:39.922
HD Request # 14 | Intraday data download complete for F.US.YMM21. Unique request ID: 10 | 2021-04-14 11:57:39.922
Removing historical data download ID 10. | 2021-04-14 11:57:39.922
Real-time Intraday chart data file updates started for F.US.YMM21 | 2021-04-14 11:57:39.922
Opened cached Intraday file: C:\SierraChart\Data\F.US.YMM21.scid. Thread ID: 2080 | 2021-04-14 11:57:39.927
Intraday chart data file opened for F.US.YMM21 | 2021-04-14 11:57:39.927
HD Request # 14 | Enabling Intraday chart updating for symbol. | 2021-04-14 11:57:39.927
Triggering next historical data download in queue. | 2021-04-14 11:57:39.927
HD Request # 15 | Downloading Intraday chart data for F.US.nqm21 to the file F.US.nqm21.scid. Service: cqg | 2021-04-14 11:57:39.928
HD Request # 15 | Performing multistage download. Downloading Minute data first. | 2021-04-14 11:57:39.928
HD Request # 15 | Download start date-time: 2020-10-10 11:57:39.000000. File last date-time: 00:00:00.000000 | 2021-04-14 11:57:39.928
HD Request # 15 | Disabling Intraday chart updating for symbol. | 2021-04-14 11:57:39.928
HD Request # 15 | Error downloading historical Intraday data for F.US.nqm21. The symbol is unknown to the server. | 2021-04-14 11:57:39.928
HD Request # 15 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.nqm21 | 2021-04-14 11:57:39.928
HD Request # 15 | Completion time: 0s | 2021-04-14 11:57:39.928
HD Request # 15 | Intraday data download complete for F.US.nqm21. Unique request ID: 11 | 2021-04-14 11:57:39.928
Added historical Intraday data request for F.US.nqm21 to the queue. | 2021-04-14 11:57:39.928
Triggering next historical data download in queue. | 2021-04-14 11:57:39.928
HD Request # 16 | Downloading Intraday chart data for F.US.nqm21 to the file F.US.nqm21.scid. Service: cqg | 2021-04-14 11:57:39.928
HD Request # 16 | Rounding start date-time down to the minute: 2020-10-10 11:57:00.000 | 2021-04-14 11:57:39.928
HD Request # 16 | Download start date-time: 2020-10-10 11:57:00.000000. File last date-time: 00:00:00.000000 | 2021-04-14 11:57:39.928
HD Request # 16 | Error downloading historical Intraday data for F.US.nqm21. The symbol is unknown to the server. | 2021-04-14 11:57:39.928
HD Request # 16 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for F.US.nqm21 | 2021-04-14 11:57:39.929
HD Request # 16 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2021-04-14 11:57:39.929
HD Request # 16 | Completion time: 0s | 2021-04-14 11:57:39.929
HD Request # 16 | Intraday data download complete for F.US.nqm21. Unique request ID: 11 | 2021-04-14 11:57:39.929
Removing historical data download ID 11. | 2021-04-14 11:57:39.929
Real-time Intraday chart data file updates started for F.US.nqm21 | 2021-04-14 11:57:39.929
Opened cached Intraday file: C:\SierraChart\Data\F.US.nqm21.scid. Thread ID: 2080 | 2021-04-14 11:57:39.929
Intraday chart data file opened for F.US.nqm21 | 2021-04-14 11:57:39.929
HD Request # 16 | Enabling Intraday chart updating for symbol. | 2021-04-14 11:57:39.929
Triggering next historical data download in queue. | 2021-04-14 11:57:39.929
HD Request # 17 | Downloading Intraday chart data for ESM21 to the file ESM21.scid. Service: cqg | 2021-04-14 11:57:39.929
HD Request # 17 | Performing multistage download. Downloading Minute data first. | 2021-04-14 11:57:39.930
HD Request # 17 | Download start date-time: 2020-10-10 11:57:39.000000. File last date-time: 00:00:00.000000 | 2021-04-14 11:57:39.930
HD Request # 17 | Disabling Intraday chart updating for symbol. | 2021-04-14 11:57:39.930
HD Request # 17 | Error downloading historical Intraday data for ESM21. The symbol is unknown to the server. | 2021-04-14 11:57:39.930
HD Request # 17 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESM21 | 2021-04-14 11:57:39.930
HD Request # 17 | Completion time: 0s | 2021-04-14 11:57:39.930
HD Request # 17 | Intraday data download complete for ESM21. Unique request ID: 12 | 2021-04-14 11:57:39.930
Added historical Intraday data request for ESM21 to the queue. | 2021-04-14 11:57:39.930
Triggering next historical data download in queue. | 2021-04-14 11:57:39.930
HD Request # 18 | Downloading Intraday chart data for ESM21 to the file ESM21.scid. Service: cqg | 2021-04-14 11:57:39.930
HD Request # 18 | Rounding start date-time down to the minute: 2020-10-10 11:57:00.000 | 2021-04-14 11:57:39.931
HD Request # 18 | Download start date-time: 2020-10-10 11:57:00.000000. File last date-time: 00:00:00.000000 | 2021-04-14 11:57:39.931
HD Request # 18 | Error downloading historical Intraday data for ESM21. The symbol is unknown to the server. | 2021-04-14 11:57:39.931
HD Request # 18 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for ESM21 | 2021-04-14 11:57:39.931
HD Request # 18 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2021-04-14 11:57:39.931
HD Request # 18 | Completion time: 0s | 2021-04-14 11:57:39.931
HD Request # 18 | Intraday data download complete for ESM21. Unique request ID: 12 | 2021-04-14 11:57:39.931
Removing historical data download ID 12. | 2021-04-14 11:57:39.931
Real-time Intraday chart data file updates started for ESM21 | 2021-04-14 11:57:39.931
Opened cached Intraday file: C:\SierraChart\Data\ESM21.scid. Thread ID: 2080 | 2021-04-14 11:57:39.931
Intraday chart data file opened for ESM21 | 2021-04-14 11:57:39.931
HD Request # 18 | Enabling Intraday chart updating for symbol. | 2021-04-14 11:57:39.931
Triggering next historical data download in queue. | 2021-04-14 11:57:39.931
No download requests in the queue to start downloads for. | 2021-04-14 11:57:39.931
F.US.nqm21 1 Min #12 | Reloading chart. | 2021-04-14 11:57:46.767
F.US.nqm21 1 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.nqm21.scid | 2021-04-14 11:57:46.778
CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-04-14 11:59:55.736
CQG WebSocket socket (1) | Closed. | 2021-04-14 11:59:55.736
CQG WebSocket socket (1) | Deleting network socket now after delay. | 2021-04-14 12:00:25.737
[2021-04-14 17:06:37]
You are getting the following message:
This means that you are not setup to get the data from CQG. You need to let your broker know about this and have them fix it for you.
Also refer to the following:
CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges
