Date/Time: Mon, 24 Feb 2025 06:33:50 +0000
Global Chart Drawings for Symbols
View Count: 535
[2021-03-04 11:00:46] |
User666529 - Posts: 4 |
Hello, I have defined a Quoteboard (Watchlist) with different Symbols and this Quoteboard I have linked to Chartbook A with different Charts (Weekly, Daily, H1). So I can do my analysis in Chartbook A by inserting drawings for each symbol sequently from the Watchlist. Now I have a different Chartbook B with M30 Charts only for all my Symbols from the Watchlist. How can I copy/link those drawings from Chartbook A to all the Charts in Workbook B. Date Time Of Last Edit: 2021-03-04 13:47:49
[2021-03-04 16:05:04] |
John - SC Support - Posts: 38116 |
Refer to the following for how to copy drawings from one chart to another: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) You will also want to make sure you enable the option for Show Chart Drawings for Different Symbols, since you are changing the symbol of the chart through the Quote Board. Refer to the following: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
