Date/Time: Mon, 25 Nov 2024 18:30:16 +0000
ChartDOM Column Width: Last Size - Right Aligned
View Count: 1160
[2014-02-28 14:46:14] |
User16114 - Posts: 153 |
Is it possible to make the ChartDOM Column "Last Size - Right Aligned" wider? Currently I can only see two digits and don't know if the last trade size was 10 or 1010. |
[2014-03-03 08:15:24] |
This will be resolved in the next release.
