Date/Time: Thu, 19 Sep 2024 22:06:38 +0000
TransAct data Feed with Sierra Charts
View Count: 1527
[2014-02-28 13:07:36] |
User31408 - Posts: 23 |
Dear, Here is my settings : Chart Interval in Milliseconds (40) & TransAct data feed When I am using the Dom through Sierra I can see the difference between Sierra Dom & Infinity Dom. Bid/Ask sizes and prices are moving faster on Infinity Dom than on Sierra Dom (same TransAct data feed) Please find attachement fo what I am saying. Just compare bid size / Ask size of the Eurostoxx for example. This is a big problem if we want to trade with Sierra Dom. Regards, |
14-02-25 20 30 29.jpg / V - Attached On 2014-02-28 13:07:31 UTC - Size: 171.77 KB - 408 views |
[2014-02-28 19:14:58] |
You need to right-click on the TransAct icon on the system tray portion of the taskbar and open up the window for the bridge program. You need to uncheck "Ticks Only". After this, reconnect Sierra Chart to the data feed with File >> Disconnect and Connect to Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-28 19:31:12] |
Well done, It's fine now. It would not effect my study on Foot Print ? Regards, |
