Date/Time: Mon, 24 Feb 2025 04:37:54 +0000
nuevos cambio y activacion de datos
View Count: 432
[2021-03-03 23:05:52] |
User921081 - Posts: 3 |
Buenos dias me pueden indicar como me puedo conectar a la data que pague el deia 1/3/2021 ya que no encuentro forma de continuar con mi trading
[2021-03-04 14:32:52] |
John - SC Support - Posts: 38116 |
From Google Translate: Good morning, can you tell me how I can connect to the data that I paid on 3/1/2021 since I can't find a way to continue with my trading
You did not go through all the steps in order to get the data. You have set your Service Package to 10, which includes the Denali Data Feed Fee, but you still need to sign the agreements and activate the specific exchange(s) that you want. Start from the following location in the Setup Instructions: Denali Exchange Data Feed: Sign the Agreements: The CME Group (Denali Exchange Data Feed Setup Instructions) If you are wanting EUREX data, then the Setup Instructions are on that same page, just go to those instructions instead. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
