Date/Time: Mon, 24 Feb 2025 03:58:59 +0000
reembolso
View Count: 460
[2021-03-03 23:05:20]
User921081 - Posts: 3
Buenos dias solicito reembolso de la data que cancele el dia lunes 1 de marzo de 2021, ya que su servicio tecnico apesta y con los cambios ralizados anteriormente en la plataforma no deseo continaur usandola ya que no recivido suficiente orientacion para hacer uso de lo que pague.
gracias
[2021-03-04 14:12:36]
We can help you with whatever technical problem you have is. That is the first thing that we should do.
To receive real-time data, it is necessary for you to activate the correct exchange fee for real-time data.
What symbols do you want real-time data for?
Also update Sierra Chart to the current version following the instructions here:
