Date/Time: Mon, 24 Feb 2025 06:41:24 +0000
Real-Time Data Agreements
View Count: 855
[2021-03-03 21:48:03] |
User99275 - Posts: 16 |
Hello, please help me fill out the form: Real-Time Data Agreements / Uniform Subscriber Agreement. I use AMP as a broker. What should I fill in the columns: "Trading Account Number" and "Clearing Firm"? Trading Account Number = account number at AMP? Clearing Firm = AMP Futures? Thank you for reply |
[2021-03-03 22:44:25] |
John - SC Support - Posts: 38116 |
Yes, what you put down for what you think is what you need to enter. Clearing Firm: AMP Trading Account Number: AMP Account Number For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-04 09:57:38] |
Thank you for quick reply. The agreements are complete, but I still can't activate the data. Error message: The Data Feed is not enabled on the account. Could you help me to solve this problem? Thank you for reply |
[2021-03-04 16:00:52] |
You need to go through all of the Setup Instructions for the Denali Exchange Data Feed. In particular, you will need to change your Service Package and then activate the exchanges. Work through the Setup Instructions starting at this section: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_ActivateService For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
