Date/Time: Mon, 24 Feb 2025 06:00:20 +0000
[User Discussion] - prices are displayed scattered
View Count: 713
[2021-03-03 21:30:42] |
User986567 - Posts: 18 |
Hello! I have connected a debt provider to Sierra Chart that uses the Rhitmic data feed. However, the display from the DOM keeps jumping around. Sometimes, however, prices are displayed scattered everywhere. I use sc version: 2234 64-bit (36335M) thanks for your help. sincerley, rené Date Time Of Last Edit: 2021-03-03 21:35:43
Private File Private File |
[2021-03-03 22:41:52] |
John - SC Support - Posts: 38116 |
We do not provide any technical support for Rithmic.
[2021-03-04 10:13:44] |
am I not on a public board where other people may have experiences with it?
[2021-03-04 14:43:36] |
For now we recommend using the Denali Exchange Data Feed for data when using Rithmic: Denali Exchange Data Feed Rithmic is working on new integration to Sierra Chart which will be much improved than what exists now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-04 21:29:48] |
But why do I not have this problem with Oneup and E2T already? I cannot use denali because I am trading through a debt account.
[2021-03-04 21:33:49] |
Try reconnecting to the data feed and see if that solves the issue: File Menu: Procedure to Reconnect to the Data and Trade Servers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
