Date/Time: Mon, 24 Feb 2025 04:04:19 +0000
Trying to connect to new instance
View Count: 404
[2021-03-03 21:12:09]
gmorgan111 - Posts: 121
I am in the process of setting up sierra charts on another computer. I have downloaded the program and downloaded the Data files from the first instance I have been using for years. When I start Sierra Charts It will not connect. I get a connection error message
CQG WebAPI Logon unsuccessful. I entered CQG WebAPI trading in the Current Selected Service and username and password although I do not remember the password and may have the wrong one so if that is the problem i need to find out how to change my password. I would appreciate your help
[2021-03-03 22:27:04]
John - SC Support - Posts: 38116
Definitely the message is stating that either the Username or Password for CQG is incorrect. You would need to talk to your broker about resetting the CQG password.
