Date/Time: Mon, 24 Feb 2025 06:09:47 +0000
I am not getting all the market depth
View Count: 516
[2021-03-03 17:51:30] |
Stupid - Posts: 30 |
I am only getting 20 market depth is there a setting that i need to fix? Thanks Padmaja |
[2021-03-03 18:36:43] |
John - SC Support - Posts: 38116 |
Go through items at this link: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-04 20:06:04] |
I have everything to 0 the one thing I dont have is the data service File: data/trade services/sc server settings I dont have that option And in all i am getting only 100 levels Please advice |
[2021-03-04 20:08:16] |
You can access the SC Server Settings by going to Global Settings >> Sierra Chart Server Settings. Most likely it is the setting in there for Max Depth Levels that is set to 100. It should be set to 0 to get all the depth levels.
