Date/Time: Mon, 24 Feb 2025 09:54:37 +0000
Trade activity log
View Count: 477
[2021-03-03 11:19:30] |
User645832 - Posts: 99 |
Is there a way to see all the open positions for different symbols on the same chart? I know Trade Activity Log but it only shows the trades for the symbol that is currently selected. What if for example I've placed a trade on /GC then changed the symbol to /ES and placed another trade? Where would I be able to see both these open positions? Thank you |
[2021-03-03 15:53:17] |
John - SC Support - Posts: 38116 |
The Trade Activity Log will give you the information for all symbols. You just need to set the Symbol filter to All Symbols. Refer to the information here: Trade Activity Log: Symbol Filter For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-03 16:14:37] |
Is is set to All Symbols and it doesn't work, once I switch symbols the previous symbol disappears from the list.
[2021-03-10 22:45:58] |
Refer to Trade Positions window: Trading Information Windows: Trade Positions Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
