Date/Time: Mon, 25 Nov 2024 21:23:35 +0000
SC Datafeed with multiple connections
View Count: 1228
[2014-02-28 07:15:37]
crazybears - Posts: 314
Hi
somewhere i read that the best way to connect multiple copies of SC to your data feed ( on the same PC) is to run 1 copy connected to datafeed and broker the others copies are connected to it.
in the copy connected to datafeed for symbols that i want receive data have to be in the Intraday file update list without no charts.
in the others copies i connect the symbol getting from the copy connetcted to datafeed.
is it the best way ?
[2014-02-28 17:46:13]
You do not need to use the Intraday File Update List.
The documentation for this is here:
http://www.sierrachart.com/index.php?l=doc/MultipleServices.html
[2014-03-10 11:24:42]
Hi
1106
I've installed more copies of SC on the same PC.
main copy is connect to CTS and use your datafeed for CME.
I would use a copy to show only TF i followed instructions written here : of http://www.sierrachart.com/index.php?l=doc/MultipleServices.html#Sharing
data is updated in real time , but DOM of TF using Sharing Data Between Installed Copies of Sierra Chart doesn't shows data
Data/trading Service of the copy connect to main copy is set as SC forex data.
[2014-03-10 17:27:11]
Check to make sure that Global Settings >> General Settings >> Use Non-Chart Data from Remote Instances is enabled.
Also refer to this section here:
http://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess
[2014-03-10 20:10:08]
I done all settings as request in your link,
one strange thing is i can display dom graph on chart and see total deep
or open trading dom and see deep
only deep on chart doesn't works
[2014-03-11 00:40:38]
ok solved ! :-D
i changed settings of Chart DOM Columns in Source copy , applying the same settings to the destination copy the Chart DOM Columns show ask/bid size
[2014-03-11 01:11:34]
Yes. We were going to say to check the Chart DOM Column Settings.
