Date/Time: Mon, 24 Feb 2025 03:15:05 +0000
P&L Column on DOM
View Count: 832
[2021-03-02 20:28:38]
User135370 - Posts: 162
Hi
I went through the support board and read the documentation but still can’t get the P&L column on the DOM to display currency format.
The documentation says left click on the top of the column but no options appear when I do. Can you help?
[2021-03-02 20:54:02]
John - SC Support - Posts: 38116
First of all, you need to have an open trade in order to have P&L displayed in that column. When this is the case, then just click on the words "P&L" that are displayed at the top of the column. Doing this will switch between the various options available for P&L display. Each time you click, it will update to the next option, eventually rolling around to the first one again and then going through them all in a circular fashion.
[2021-03-03 03:13:05]
Ok I see thanks
