Date/Time: Mon, 24 Feb 2025 02:54:40 +0000
Change % by candle?
View Count: 762
[2021-03-02 16:44:52]
bluejune - Posts: 34
I'd like to drag my mouse over the candles/line charts through out the day and see what the change % on the day is for that exact candle. Is there a way to do this?
[2021-03-02 18:09:08]
John - SC Support - Posts: 38116
You would need to add the Percent Change since Open study and then you can see the change for each bar in the Tool Values Window.
Refer to the information here:
Percent Change Since Open
[2021-03-02 19:34:24]
Thank you, I tried doing Percent change from Previous close for a 1 day time frame with 1 minute candle sticks
Any idea why I am still only getting the % change from open and not from the previous day close?
[2021-03-02 20:13:06]
Why do you say that it is not comparing against the previous close. We just took a look to make sure and it is doing this correctly. Keep in mind that you will not get any result that is a 1.0, as the Previous close will be compared the its previous close, and then the new bar for the day gets compared to the Last of the bar before.
[2021-03-02 20:19:48]
For example, ASLN is currently down 15.6% today but the Percent Change Since Previous close shows -12.2%....
Is this how it should be calculated?
https://imgur.com/a/J0qclrw
Date Time Of Last Edit: 2021-03-02 20:21:52
[2021-03-02 20:45:55]
The Daily Change is based on the Settlement Price and not the Last price of the Last bar of the day. So these are two very different numbers. To compare them, you would have to use a Daily chart.
