Date/Time: Fri, 18 Sep 2026 19:00:00 +0000
Prop firm trading
View Count: 5190
[2021-03-02 16:28:53]
User967852 - Posts: 26
I would like to do a challenge for the prop firm: oneuptrader. They say that they cover fees for data during the evaluation and continue to do so after the challenge is successfully passed. When I asked them if Sierra was one of their supported charts, they replied saying that Sierra does not officially support a rithmic data feed(which is what they use). They suggest that I use bridge files to rectify the issue (Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward) if I still want to use Sierra for their program. My question is would this be a viable solution and would you recommend that I try this firm using Sierra? Also, if they cover the fees do I still have to pay for the denali exchange?
Thanks,
[2021-03-02 18:05:14]
John - SC Support - Posts: 47939
The main thing to be aware of is that we do not give any technical support for Rithmic.
If you are getting the data from Rithmic, then you would not need to use the Denali Exchange Data Feed. Refer to the following for how to deactivate the Denali Exchange Data Feed:
Denali Exchange Data Feed: Canceling an Exchange for the Denali Exchange Data Feed
[2021-03-02 18:24:20]
Ok thanks, but do I still have to use the bridge files?
[2021-03-02 18:49:02]
Yes. You need to install those files in order to use Rithmic with Sierra Chart.
[2021-09-07 06:31:05]
User686069 - Posts: 1
Can you please send me link to download files. thank you
[2021-09-07 08:00:08]
Those are not relevant any longer. Instead refer to the instructions here:
Rithmic Trading Platform Service
