Date/Time: Mon, 24 Feb 2025 03:25:40 +0000
cqg and Denali issue
View Count: 513
[2021-03-02 15:41:33]
User68acg - Posts: 15
Hi.
I am totally confused.
I have an amp ac..
I pay for Denali and a few days ago had to resign for cqg routing as now required for live trading.
I got that happening correctly but now it has stopped.
The symbols are cqg, I have a live connection but no live data - stopped around 10 am Ldn
I get the message that the symbols ( which are the cqg ones) are unknown and and realtime data is not allowed ID=1
I am not alone with this issue.
Do you have any suggestions please.
Andy
[2021-03-02 17:30:18]
John - SC Support - Posts: 38116
Check to ensure that the option for File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. If it is not, then set to Yes and then select File >> Disconnect then File >> Connect to Data Feed.
If this does not resolve your issue, then we need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
